I have a 1994 Merc Offshore 3.0L 225hp carbureted two-stroke with about 625 hours on it.
When I brought it in for annual service recently, the shop manager noted that the #6 spark plug did not look as clean as the others. He said it was "crusting up," with "whitish debris" on the plug. He recommended pulling the plug every now and then (say, after every three trips out) to keep an eye on it.
He told me at the time that the psi on all the cylinders looked good. However, I see on the receipt that the pressure on this #6 cylinder is a bit lower than all the others:
1) 115
2) 113
3) 118
4) 115
5) 118
6) 105
Any thoughts on this? Is there a probable cause for the observed symptoms (gasket? rings?). If this continues to get worse, how would it show up in performance? Would a failure likely to be immediately disabling, or gradual?
1) 115
2) 113
3) 118
4) 115
5) 118
6) 105
