Re: 1990 Evinrude 140 v4 Grease fittings
Tashasdaddy, thanks for the input. Now I am sure the 90 degree fitting is for the tilt. As ezeke pointed out, I was looking for a second fitting for the swivel. Somewhere along the line I had heard it refered to as the steering tube. Ezeke, thanks, I'm bettin thats what the deal is. Any suggestions on how to heat it up. The steering is very "easy"; can turn the wheel with your finger. I just don't like seeing that upper end of the swivel with no grease oozing through. Do you suggest drilling a new fitting at the upper end of the swivel if heating does not fix? Thanks again to you both. I'm new to the forum and think it's great. Mike
