Re: Is There an Evinrude Mechanic In The House
Howdy.
Welcome to iboats.
No, Mark. There is no minimum number of psi specified because there are too many variables in the measurement process.
Big OMC V6s typically compress 80psi or more, which is lower than many other models, but individual examples might give you 125psi.
I am sure that I am not the first to tell you that all 6 must compress within 10% of each other and it is that spread that tells you about the engine's health.
I have never, in 60 years of messing with outboards, seen one wear out. I have seen thousands in which one or two cylinders lose compression due to a failure of some sort, or excess carbon buildup. Those are the engines that need rebuild. . .broke engines, not worn out engines.
Good luck.
