rectifire
Alen
I fitted a Rectifire on my 10hp thinking it would run my running lights and top up battery
My problem is i get voltage if the revs are high but still no current not even 1 amp is a 10hp suitable too run a rectifire Thank,s Al
j_martin
Re: rectifire
Rectifire .... What occurs 20 hours after a chili eating contest.
What rectifier are you using, and what are you driving it with?
Alen
Re: rectifire
don,t know what make it says IOR
QBPC3504A It is an inch square with a corner missing and a hole in the middle,It has 4 spade connections marked + - and two are marked with a number 2 it was fitted by a marine shop I also have the same one on my 25hp tohatsu and swopped them to see if there was a fault with the rectifier:)
It is connected to two wires that come from under the fly wheel
