69starcraft
- Jul 11, 2007
- 169
I'm guessing this is a long shaft motor? I did a search and everyone talks about an extension that should be pretty obvious. I don't see any "extension" but the lower unit seems pretty long.
I got this motor free. Was sitting for approx 30+ years in a basement.
A little pb blaster soak and she spun freely with minimal work.
Cleaned the points, cleaned the carb, a shot of ether and she fired up the third pull.
Lower unit is now off to inspect and most likely replace water pump. If it is in decent shape I will keep it in for barrel run purposes only while I finish evaluating the motor.
2 things I need to address off the bat is the throttle linkage is broken. A little tab the fits in the geared slot is broke off. Might be able to use an old bolt and the drill press to re-fabricate.
Other problem is the Shift rod is broken off from the handle up in the leg. Any ideas how to address this? Is removing the leg difficult? This is the upper shift rod and what was rattling around in the leg. It was bent so I sliced a chunk off and slid it out.
Anything Else I should look for in evaluating this motor? I'd like to put it on my feathercraft. I think the motor shaft is same size now that I just looked at my feathercraft resto link. The 16 is in storage so I can't get at it to measure, but in the pics it looks pretty long too.
I still have the working Johnson controls from the old 25 that went MIA and they fit this motor. It would be nice to put this on the feathercraft.
I am mostly worried about engine internals....I am a competent mechanic, but have never messed around "inside" a motor. i.e. rings, splitting cases, bearings, etc.
Last question....any ideas on how to do a compression test on a motor that is a pull start only, and has a compression release so you can pull it?
