ispurpleafruit
- Dec 26, 2007
- 14
I have a 1967 120 hp mercruiser #2055736 with a alpha one sterndrive #2072395. Last week I was fishing on the delta and ran through some weeds that did not clear the prob so I stoped, put it into reverse and gunned it to clear the prop. after doing this the boat would not go back into forward gear. After 5 minutes of trying to shift it it finally went in gear and got me home. I had this problem 1 year ago and it was the lower shift cable. So I replaced it and it has run great all summer long until now. At first I though it might just need adjusting at the shift plate but once I got to looking at it the boat wont go into either gear without adjusting the cable. I have not yet tryed to adjust the cable because If I dont get either gear now, then I can only adjust it one way or the other and this will only give me use of one gear or the other. The shift handle feels a little stiff but not significantly more than it use to. I tryed to pull the sterndrive off and check the shifting mechanism but couldn't get the drive off. I have a manual for the boat and the only thing it said is to put the boat in forward gear, so I did this but i could only pull the drive about 1/2 an inch away from the gimball housing. I was confused by this because 1 year ago I had the drive off and did not have this problem. Should I have put grease or anti-sees on the yolk wear it goes into the flywheel? BUT when I had the drive 1/2 an inch apart I could see the end of the shifting rod or what ever it is called and it seamed to move just fine. I pulled the lower half off of the sterndrive and I can get the lower half in and out of gear with a socket no problem, so does this mean that I dont have enough travel either way on my shift cable. I dont think this can be the case because the only way I can think of getting more travel is to change the shifting handle. but I have been running the boat all summer just fine. After I changed the shift cable last time and adjusting it, it always went into forward just fine. But reverse you had to push the shifter a little further than I thought you should have to but it always shifted before the RPMs raised so I never thought it was a problem??? Any advise or ideas to help me get the drive off and fix my shifting problem would be greatly appreciated. anything at all!!!
Thanks Andrew
Thanks Andrew
