OldJohnson6hp
- Mar 19, 2009
- 53
This one has me stumped. No spark in top cylinder. I have done the following:
Switched plugs..plug is good
Swapped Coils...Coil works on other side
Condensor switched..Works fine on other side
Checked point gap..spot on ---(did not switch these around)
Checked plug wire with multimeter--used sounder, red in plug cap black on coil side nice audible beep
Previously replaced coils, points, condensors few months ago..motor has been running fine. Went to go out tonight, would not start, checked spark and found dead on the top cylinder
Any ideas guys? I have no idea what could be wrong here..could the point just die? They are clean..heck they still look new! Didn't switch it to the other side to check..I'm lost.. everything else seems to work when placed on the other side..nice big healthy spark.
Thanks for any help with this one..
