Can anybody help? I have a 1980s 50 hp Merc that will start fine after battery is charged, i can go off and fish at 1 or two locations and then the engine progressively becomes harder and harder to start until its dead. Yesterday i was able to pull start it to get back to the ramp, but once back at the ramp i tried to fire her again and she wouldnt even pull start. There is enough power in the battery to easily operate the tilt/trim (even when i was back at home) but the fish finder was turning itself off when i was in strife out on the water. This is the second time this has happened. The first time i put it down to a weak battery ( the one im using has only had 3 trips out on it in 7 weeks and has been fully recharged after the first non starting incident) and a couple of slightly loose nuts under the cowling, but that clearly is not the case and i guess im now stumped. Any help or advice would be greatly appreciated. I should probably add to this that im a complete novice and am only just finding my way with boats engines etc.
