Tscott8201
- Dec 13, 2007
- 18
I just brought my 22' Aqua Sports center console home. She has been in covered storage for about 3 years. Before storing her I had discovered the dreaded rotten deck. Last night after I got her parked in the shop, I inspected the damage. The decking has completely dried, but is rotten most of the way around the t-top and center console. I need to replace the core of the deck before I can use the boat again for fear of losing the t-top.
I plan to remove the t-top and center console, then cut off the top layer of the deck in one or 2 pieces. once complete I can remove all the rotten end grain balsa, and replace the core by laminating it to the still in place bottom layer of glass with resin. I will then do the dame with the top layer of glass previously removed. While the deck is opened up I will laminate in new anchor points for the t-top directly to the stringers. This will hopefully stiffen the deck and help keep it from leaking in the future.
Will my plan work, does it make sense?
Would you go back with end grain balsa, or would you upgrade to a better material? I have found a selection of new core materials here:
http://www.jamestowndistributors.co...ls and Foam&categoryId=399&refine=1&page=GRID
I would however try to find a local source for these products to save on shipping. I live in North Florida so this should not be a problem (lots of boats here ).
let me know what you all think, and thanks in advance for the help. I will get pictures up here shortly, if I can find my digital camera.
Tom
Tom
