ga shrimper
- Dec 27, 2009
- 5
Im wanting to know a little information about my new used motor. I recently replaced the control cable on my motor because i thought the old one was worn out. My motor would not go int reverse even with the cable adjusted all the way out. So i bought a new cable and it had to be almost all the way adjusted out. When i did that the motor would go into reverse on the flusher easily and like it was supposed to. When i took the boat out and put it in the water the reverse went back to grinding so i adjusted it all the way out. then it would go into reverse but if you gave it some throttle it would jump back out. Does anyone know what the next thing to consider to repair would be.
