Re: Rebuilding stringers...help
Great thanks for the advice so far!
So after taking up the floor I have noticed that the stringers are not F/G.ed down to the boat infact they are free floating.
So far here is my plan for the new stringers.
1 cut stringers to match hull shape
2 space stringers where old ones were and Epoxy them in place.
3 F/G around wood
The dilema: this boat looks as though it were worked on by someone who did not know how to build proper flooring and they simply left the stringers free floating so there is was no F/G structure to work with, simply a blank hull.
the only thing secured to the hull was the actual floor which was F/G down.
THE MAIN QUESTION: Are the stringers supposed to F/g to the hull or should they be loose, epoxied.... ?
here is a pic with the floor removed you can see the 2x4 sits right on the hull with no type of glue just free floats.
