Re: Force 120HP exhaust (fire) coming from fuel pump pulse port
Hello and thanks for the replies. I have since checked the reeds, the compression, cleaned the carbs, replaced reed gaskets. I have found that the problem is basically that the lower carb is running lean and it is the leaness that is causing the backfire,, I just have never seen one actually fire into the crankcase chamber. I have switched the reeds from top to bottom and vise versa with no change. The last thing I tried this afternoon, was to switch the top carb with the lower one (can be done with some modifications). This made the backfire on the lower carb to stop. I can't find what was making the bottom carb run lean, but it is working better with the bottom caeb in the top position. My conclusion is that the bottom carb is getting extra air somehow, it dosen't effect the top as much because the fuel pump pulse port is in the cyl#3 position. I am going to leave the carbs the way they are and see how it runs. In the meantime, I will be looking for a replacement carb (used), a new one is NLA. Thanks again for the replies, I will check back for any info you can lend, like where I can get a good carb, or , any suggestions for where the extra air may be getting in the carb vaenturi. By the way, this motor is a 1999 120HP Force by Mercury.
