Re: Problem with surge brakes
Originally posted by Chris_P:<br /> If I stop slowly the front axle starts hopping or studdering. Chris
The front axle isn't carrying as much weight as the rear one. <br /><br />Have the axles changed to where the rear axle has the brakes. It will stop better, and cut out the skidding/hopping.<br /><br />This shouldn't be a big deal. They'll swap just fine, and you'll have to add a couple feet of brake line to make the connections.<br /><br /><br />Another solution is switch over to electric brakes--- on the rear axle.<br /><br />For the conversion you'll need the brake actuating solenoids to replace your hydraulic 'wheel cylinders', some wire, and a controller. All the other brake components will remain-- shoes, back up plates, drums, springs, etc..<br /><br /><br />The dash mounted controller for them is adjustable and will also have a button where you can engage the trailer brakes independantly like 18 wheelers do. This is good when you're coming down hill on a slick road surface. You can slow down just using the trailer brakes and prevent a 'jack knief' condition.<br /><br />I've known several folks who converted to electric brakes, but none who went back to hydraulic, or any who switched from elec. to hyd.
