pcmpete
- Apr 24, 2009
- 328
Hi all, I get a clunk sound when engaging the drive, I have read that it can either be the idle is too high and/or there is too much end-play in the 270's shaft.
My questions are:
1. What is the lowest the idle can be set at on the AQ130c? The smoothest/lowest I can get is 800rpm (with pertronix ignitor)
2. I have not yet checked the end play in the drive, but if there is too much end-play can the 'Nut' be replaced without removing the upper drive unit?
Thanks for your time.
My questions are:
