Re: Outboard Air Cooled Disel Engines
Looks to be this:
STAR BD10 Diesel Outboard Motor
10 HP, single cylinder, four stroke, air-cooled, transom operated, long shaft, rope start, manual tilt arrangement diesel outboard motor.
1. Propeller Shaft Power (kw/HP) : 7.35 / 10
2. Model : BD 10
3. Rated Speed (rpm) : 3,600
4. Bore/Stroke (mm) : 86 / 70
5. Type : Single Cyl, 4 Stroke, forced
air-cooling
6. Displacement (L) : 406 cc
7. Fuel consumption at Rated Speed (g/kw.h) : 285.7 ( Approx. 2.5 ltrs/hour)
8. Starting System : Manual / Electric
9. Gear Mode : Shaft gearing
10. Gear ratio : 2 : 1
11. Gear Shift : F ? N ? R
12. Net Weight (kg) : 72 kg
13. Overall Dimensions - L x W x H (mm) : 1,340 x 650 x 550
