Re: Differences between PL's
PL premium polyurethane adhesive is a construction glue. Its allot like Liquid nail. Its normally used in building construction. Some folks, including me, use it as a bedding compound for stringers.
3M 5200 is specifically designed for marine use. It is used for "bedding", but in a different way. It can also be used as a marine caulk or as an adhesive. 5200 is generally used to seal fittings and thru-hulls. It is also good for sealing major components that go under water. PL is not suitable for that.
3M 4200 is just like 5200 but it is considered a removable bond where 5200 is considered permanent.
