Hey guys - I have tried to find the answer to my question but cannot find anything, so here goes.
I live in TX and I am trying to "winterize" my 200 HP Merc. Outboard (Nitro Series). So I drained and replaced the lower gear lube and then I put Marine Sta-Bil in the fuel system. So, next I was going to run the Sta-bil through the fuel system by letting the engine run for about 10 minutes or so.
So I hooked up the water muffs on the intake and started the engine. I turned on the water full blast and then cranked the engine. I let it run for about 10 seconds and no water stream from the pee-hole, so I shut it down. I cleaned out the line and then I hooked up the hose to flush the water system until I got a good stream out of the pee-hole. Then I cranked it again and let it run for about 30-45 seconds and nothing but a little "spitting" from the hole - just a little bit. Is it possible that there was just not enough pressure from the hose? Did I do anything bad from letting it run that long?
Any advice would help as this made me pretty nervous today on football Sunday no less.
Thanks,
Willy
Thanks,
Willy
