Hi my names Harry,
I'm working on this 1994 Force 15hp outboard motor, has had issues starting. Recently cleaned fuel pump, filter, diaphram and carby they appear to be in good condition. Fuel is surging out of primer bulb and the motor wont idle so I took the bulb of and put my finger over the hole and it stalls. I relies the fuel bulb attached to the tank is one way but this bulb appears to be two way. Also blowing alot of smoke (fuels clean). Is this because its running rich, tried to lean out slighly, prob persisted! Any suggestions. :
