Re: Minn Kota Trolling Motor Power Center
Junk, don't waste your money...cheap thin plastic and even cheaper electrical components. I got one of these with my boat and it was so corroded I tossed it out of the boat during its first cleanup and it flew into a million pieces when it hit the ground...the voltage "fuel gauge" is next to useless also.
Put the money you save into a good AGM battery and some good brass terminal clamps with the red rubber boots to protect from shorts...you will be much happier and it will last the life of the battery.
Easier to carry too.
