Re: Grinding Question: Part 2
I agree with the above, but with one note.
If you're using epoxy to attach new stringers, and you still have part of the tabbing or attachments in place from the old stringers, you might want to remove the old attachments even if they're in good shape.
This is because new tabbing with epoxy will be stronger than the original poly resin tabbing, simply because epoxy is a better glue than poly. It'll work to attach the new stringers to the old tabs with epoxy, but where the old tabs are attached to the hull they're attached with poly resin (at the factory).
So if you keep the old tabs you're not getting all the benefits of the epoxy you're paying for.
But you may not care, or you may be using poly.... up to you, like so many other repair decisions.
Erik
