BigBoatinOkie
- May 28, 2009
- 763
I've been winterizing my '84 Wellcraft 180 Elite XL with Merc 228hp 5.0 (Chevy) and Alpha 1 Outdrive. I would like to telll you what i've done and see if I've missed anything. Here goes.
1)Added fuel stabilizer
2)Change motor oil and Filter
3)Fogged Engine
4)Drained cooling system as follows: pulled 4 plugs (2 block, 2 manifold), drained hose at power steering cooler, big hose going into water pump.
5)Pulled of thermostat housing and filled block with a/f
6)pulled hoses going to manifolds and filled with a/f
7)Lubricated shafts on power steering hydraulic ram or whatever you call them.
8)Lubricated every pivot point I could find on carburetor and linkages
9)Lubricated pivot points on shift cable and shift cable where it connects to the shift lever.
10)Changed geal lube in outdrive. Greased spline on last prop change a couple months ago.
11)Will be changing fuel filter today.
12)Will give the boat a thorough cleaning inside and out.
If there is anything that I need to do before I put the cover on this thing and put it away for the winter, please let me know.
P.S. I noticed that the thermostat was in the open position when the engine was cold. I was expecting it to be closed. Will I need to change it in spring, or is that normal?
Thanks for any help, it'll help me sleep at night.
3)Fogged Engine
