Ok, I have a new problem. I am trying to replace the band fitting on the tilt cylinder. To do this I need to remove the pivot shaft that goes through the top of the tilt cylinder. I can get the nuts and washers off but the shaft going through the bracket won't slide out. I've tried to tap it like the manual says and I get anywhere with it. Do you guys have any suggestions. Thanks
