shane56inlet
- Dec 3, 2009
- 20
OK, i have a 1975 40hp johnson. while replacing the water pump i ran into a couple issues. the driveshaft is stuck in the head but the lower unit came off. i tried hanging it upsidedown and everything. so i came up with another plan i sliced the middle unit in two places so i can slide it around the water pump after i replaced it. while replacing the impeller there was nothing left but the ring and a little plastic. so after i replaced everything i put it back together and it took a min before it pumped water but it did. Then it stopped. i took the lower unit off again and everything was fine. tried it again and it only spit water when it was reving high. so i took it down to the docks praying that it would be fine, when i started it no water pumped i drove in a circle and it still didnt pump so i brought it back in because i didnt want it to overheat and sure enough it wouldnt start up again beacuse it was too hot. now im stuck. please help me this has been a month project that i really need to finish
