cheeseburger
- Jul 25, 2003
- 17
Hello,
I have a problem when starting my engine, it revs up to like 1200 rpm for a second, or sometimes actually stalls when starting. It kind of reminds me of a choke sticking on a carburated engine.
After a few seconds, the RPMs drop back to normal.
Most of the time if I am idling around, it idles fine. At some times, it seems to be missing.
The engine is running great when going all out.
I have recently replaced the plugs, plug wires and Fuel Filter.
I have a hotfoot peddle installed. At first I thought this may be sticking but I verified it is not. I put a new throttle cable in about 6 months ago.
From what I have read, it appears to be the Throttle Position Sensor.
About to find out after spending 180 bucks to order one. Hopefully, they will take it back if this is not the issue.
Any other thoughts?
I had a similar problem about a year ago where the Tracker valve was bad but the symptom was a bit different. The speed at idle constantly changed from around 600 to 1200 and back over and over again.
Any other thoughts?
