Re: Floor Rot 1974 Silverline Tri- Hull
You "can" do what you propose, but it will add weight, and not enough structure for the increased weight. I will recommend against it, but you are free to do as you see fit. I will say that you would be better off with 3/4 ply if you are going to do what you propose.<br /><br />When I opened my floor, I just wanted to cry. Then the rage set in. Slowly, acceptance, and finally, resolving it. I weighed the various options, and they all came up wanting compared to just buckling in and doing it as right as I knew how to. What I really wanted to do was to strip it, chainsaw it into four equal parts (as required by my landfill), and haul it to the dump. But, I had this idea, and I felt that if I tore her down and built her up from the naked shell, I would always know the condition. You go and buy a boat, it is always a guessing game. I have no guesses, no worries, and I have spent the summer thrashing this ugly thing and it took it all in stride. I say if you do not feel you are up to the full rebuild, you may want to consider another hull, otherwise you can build up a boat that is better than new. Good luck either way....
