Alpheus
- Aug 3, 2009
- 1,757
I have a quick question pertaining to the shift cable on my boat. I have a Mercruiser 270 with an Alpha 1 Gen 1. Today I was out at the boat and installed a rebuilt carb and started the engine. The engine was producing a sound that sounded like you are trying to put a car with a manual transmission into gear without pushing in the clutch.
I immediately shut the engine down to have a look. The PO stated that after He had replaced all of the bellows and a new shift cable that He never hooked the shift cable back up and that He lost all of the pieces to do so. I tryed to pull the cable by hand with no luck. the prop spins both ways but it has a clicking sound to it. I had another guy turn the prop by hand while I tried to push or pull the cable, also with no luck.
I started the engine again with the same sound. I tried to push and pull the cable with no movement. The gentleman that was outside the boat told me that the prop was spinning but I forgot to ask him in what direction.
So my question is how hard is it to pull on the cable to move outdrive in and out of gear? I can get the cable to move about half of an inch. Any info would be greatly appreciated...
