Re: 1973 glastron v173
70s Glastrons were beautiful hulls with really sexy lines, that did handle well. Early Glaston did invent the deep vee hull and they were extensively copied.
HOWEVER: Yours is severely underpowered! It is most likely rated for 125 or slightly more. With the 50 it won't go more than about 20-25 MPH, and less if you are carrying a couple of people. And if you get into trouble on the big water, you will not have enough reserve power to stay out of trouble.
Want to know all about your boat? Go over to Classicglastron.com
As far as Erie-- That's a big water--17 footer--Good day, OK. Bad day? You will at least brown your pants but that hull will most likely get you home. Just be certain to always wear your PFD. Use the rule of threes for fuel: 1/3 out, 1/3 in, 1/3 reserve. Buy a hand held GPS and learn how to use it , especially waypoints and goto function -- Go too far and everything looks the same, even in sight of shore. GPS will get you back even if you don't know where you are (impossible with a GPS and charts, you always know where you are.)
