I'm pretty sure I'm not getting any fuel through my carburetor on my 1990 35 hp Evinrude. I've rebuilt a lot of Honda carbs before, and I did all the things to this carb that I would normally do: check/replace gaskets, spray carb cleaner, shoot compressed air through it. One difference though. The main jet does not seem to come out. Does anyone know, is it somehow sealed or otherwise stuck in there? I can't for the life of me figure out why fuel isn't getting through the carburetor. It used to run fine. When I used to prime it, a little fuel would trickle into the bore. Any ideas or suggestions?
Mahalo,
Derek
By the way, fuel is getting into the bowl and into passageways in the top part of the carb where the low speed needle is as well.
Mahalo,
Derek
