where to get peices for outer transom plate 86 alpha drive
lime4x4
I want to rebuild the outer transom plate and ring on 1986 alpha drive unit. I'm looking for the bushings,seals,lower pin,steering pin and lower bearing. Any good places to get this stuff?
Bt Doctur
Re: where to get peices for outer transom plate 86 alpha drive
PM`d you my number. I can check some sources.
Don S
