Re: 6 hp conversion from long shaft to short shaft
Never done one as new as yours, but on the older motors the swap entails the exhaust housing/leg extension, driveshaft, water tube and shift rod connector. If you do your own motor maintenance it's not hard to do...helps to have a good manual and be familiar with your motor.
