The last few trips my reverse has been grinding into to gear really bad, and the most recent trip I couldnt shift into reverse at all even when I stabbed it. The motor would just rev and make an awful noise like teeth slipping. Forward gear works perfect.
I changed the lower unit oil to check for any damage this evening. I was thinking since I just recently installed the motor maybe one of the throttle cables is loose or not adjust correctly?? Here's some pics of of the lower unit magnets. Do the metal shavings look excessive or is this normal?
