Hey guys I have a two part question.
1990 Evinrude XP150
1. Trim motor is continuously running. I hooked up my battery charger and the trim motor started running on it's own, but the motor wasn't moving. So I unhooked my charger and it continued to run. The trim motor would run for about 5 seconds and then stop for about 5 seconds repeatedly. The only way I was able to get the motor to stop doing this, was to remove the two relay boxes.
2. Motor will not trim under load, Out of the water or just sitting in the water at idle, it trims up and down fine, but when going to plane out it trims down on it's own and will not trim up.
If you guys can point me in the right direction with this it will be greatly appreciated.
1990 Evinrude XP150
