I had a minor fuel leak and decided it was time to replace some lines. In the process I discovered the small plastic "T" was damaged and was able to pick up a replacement the next day. I also figured I'd pull the carbs and clean them out since the motor had sat awhile. Everything is back together except for the small diameter fuel lines coming from the fuel solinoid thru the new "T" and back to the carbs. I haven't yet cut the new fuel line to length, and can't for the life of me figure out where exactly the lines should go. The VRO is removed an not in play, I have the manual for the motor, but haven't found anything in there.
Thanks
Thanks
