more old Johnson problems
milmo1
Back in spring, i had some trouble starting my 20 hp 1966 Johnson outboard. It is a pull start, tiller drive btw.
After many attempts, including replacing the points and condensers, adjusting the timing cam, and using a carb off a parts motor, I was able to start and run the motor in a test can. I did however, have to manually blip the throttle roller to keep the idle strong. I never did get the chance to run her on the open water.
This weekend, I launched the boat. The old motor gave me some fits at the dock, as it would take 3 or 4 pulls, run for 3 seconds and stall. Then 3-4 more pulls, run and stall. As it struggled to maintain an idle, it would also make a horrendous knocking noise, which I thought might be the recoil mechanism as the motor shakes violently just before stalling. After appx 12 times, I was able to maintain idle - but it was running on one cylinder for a short time.
So, we motored out at a nice low cruising speed, maybe 1/4 throttle. I twisted her open, and nothing. Just the same low speed cruise. After 15-30 seconds - BAM. She'd take off like a raped ape. However, if I backed down to 3/4 throttle...we dropped back into that real low cruising speed. Open her back up, and 15-30 seconds later she would fly. Over and over again I repeated this.
I just don't know what to think?
Any ideas?
Thanks all.
bktheking
Re: more old Johnson problems
You are intermittantly firing on 1 cyclinder, that's why it was a PITA to start and why it would take off like a "raped ape" lol. Something is going on under that flywheel be it coil alignment, a wire shorting or not making contact, a bad coil, something electrical by the sounds of it.
Mas
Get a spark gap tester and see how far the spark will jump. Also, run the motor in the dark and see if the plug wire etc are grounding out by the presence of an errant spark.
mas
samo_ott
mas
Running in the dark works well. To make it work even better, get a spray bottle of water and mist the wires... You'll see in a hurry if they are arcing through anywhere.
milmo1
I have checked the spark, and it is thick and blue. I have not tested how far it will jump. I did replace the points and condensers, but not the coil.
It will run on one cylinder at times, but not often. When I was in the "low speed cruise" it was smooth - firing on both cylinders. Then it would suddenly take off without rhyme or reason.
Someone told me I may be sucking air through a fuel fitting - any thoughts on that?
lindy46
Sounds like a coil heating up and cutting out. I'd replace the coils and the wires.
oldrudedude
You replaced the carb. Did you do a link/synch?
My thoughts: If your spark checks out ok, the "hesitation" you are experiencing could be a "lean running low speed carb circuit" issue (or improper timing). When you give it throttle, the lag occurs as the vacumn builds up enough to draw fuel through the high speed jet --> then it takes off. Try adjusting the low speed needles out a bit.
Mas
Try running it without the hood. Maybe you're got an exhaust leak & it's choking for air??
Mas
jbjennings
I also think it's a bad coil, and it may seem to run smooth on on 2 cylinders, but the sudden take-off is when you get the 2nd cylinder actually making power. The coils on that motor are common problems.
JBJ
milmo1
Although I replaced the points and condensers, I did not replace the coils.
I did not link/synch the carb. I'm guessing that procedure is in the top secret files above this forum. I will do this if I can figure it out.
I found my spark "jump" tester, I will check the spark health.
Then I will report back.
Thanks all.
mikesea
Those coils will give fits if old.They can leak when hot,or when they just feel like.However,if your spark is good as you say,did you do the old squeeze the ball trick to elimate the possibility of a fuelpump problem?
milmo1
Last night I did the spark jump test in the dark. I'll be darned if that lower cylinder wasn't firing regularly. On any given pull, I may get 2 sparks, 1 spark, or none at all. Then I extended the jump distance. The top cylinder gave me 2 consistent long sparks. When I tested the lower cylinder, I think I got 1 long spark in 5 pulls.
I'll post again after coils are replaced...
Mas
It's amazing what a $10 tool will tell you!
Mas
14ftgrumman
If you have 1 bad coil, replaqce them both,and the plug wires. Use only solid copper core wire. Hard to find, but if you tell the car parts guy that you need a universal set for a 4 cyl farm tractor, you should be able to get all the wire and associated stuff. For God's sake, don't tell him it's for an outboard, he'll tell you that he doesn't have marine parts.
steelespike
They may have the wire kit right here at iboats.18-5225 NAPA does carry the kit in their 600 page Marine Products catalog.18-5225 Unfortunately some branches don't know about the catalog.
milmo1
The fun continues...
Replaced coil. Rechecked spark - great! Long blue and strong from both cyliders. Ran in a test can well. Took down to the lake, started right up, idled well. Backed away from the dock, motor died 50 feet away. Pulled it enough times to lose the skin on my hand, but only managed to get it to run a few seconds at a time.
Got it back home, won't start at all - but strong spark is still present. Pulled outgoing fuel line from pump - pumps nice with each pull on the starter cord.
Searched the top secret file for "link/Synch" - but don't see it...
Please Help...
bktheking
Try spraying some 50:1 mix into the carb and see if it fires. Could be a carb problem.
milmo1
I think I have a carb problem, but I just got the motor to start and idle in the can. Since it is dark, I noticed a ton of arcing from the plug wires. I need to replace them. How do I access them for removal? My Clymer manual is pretty vague.
Thanks!
Maveric7383
Napa sells the solid core wire by the foot, im sure they also sell the terminals too, and if your lucky they might have the crimping tool is stock too. the only other car place that might sell something like that is carquest.
