help me out is the the new or old pattern that is staggerd?
K krisnowicki Lieutenant Junior Grade Joined Jul 11, 2007 Messages 1,172 Nov 16, 2009 #1 help me out is the the new or old pattern that is staggerd?
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 70,524 Nov 16, 2009 #2 Re: Starter patterns Ayuh,... There's nothing new or old about it,... It's 153 teeth, 12" flywheel is Straight across,+ the 168 tooth, 14" flywheel uses the Staggered...
ErieRon Chief Petty Officer Joined May 5, 2009 Messages 463 Nov 16, 2009 #3 Re: Starter patterns Are you guys "Code Talkers"?
Bt Doctur Supreme Mariner Joined Aug 29, 2004 Messages 19,111 Nov 16, 2009 #4 Re: Starter patterns "Mechanics Speak" so to speak
K krisnowicki Lieutenant Junior Grade Joined Jul 11, 2007 Messages 1,172 Nov 16, 2009 #5 Re: Starter patterns Isn't the split after 86 and before
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 70,524 Nov 17, 2009 #6 Re: Starter patterns krisnowicki said: Isn't the split after 86 and before Click to expand... Ayuh,... Like I said, it's Not time related,... Chevy has been using 2 different flywheel sizes since the 60s, or earlier.. The rear main oil seal went from 2pc. in 86 to 1pc. in 87...
