Re: Remove spindle lube for bearing buddies?
Why?<br /><br />Parts are readily available at any auto parts store, its just an axle nut and retainer. The bearings are no different than any other hub and can be had anywhere any other bearings are available.<br /><br />Look, bearing protectors by any company are an aftermarket joke that at best do very little and in most cases cause more problems than they ever solve. Spindle lube systems, by contrast, actually offer a sane way to fully load hubs so that water intrusion is a thing of the past. In short the spindle lube systems are far superior to any bearing buddy no matter who the maker is. If anything the sane way to go is to see how far you can toss the bearing buddys and convert to a spindle lube system, going the other way around is simply a mistake.<br /><br />Thom
