OC Rider
- Mar 14, 2008
- 31
Hello,
I'm new here and was hoping somebody can help me out. I have on my boat a Sony head unit pushing 2 6x9 Pioneer and 2 5 1/4. The head unit has a Fosgate amp pushing 1 12" fosgate sub. Everything works fine but when i turn up the volume to about 18 everything shuts off. I noticed that if i turn the lows completly off the headunit i can turn up the volume higher but than i get very little base out of my sub.
I also noticed that when i fade the sound to the front speakers it doesn't matter if the balance is to the right or left, both speakers are working. When i fade to the rear the balance works when i move it from right to left. Is that a wiring issue at the head unit? How do you recommend i fix that?
Any suggestion or help will be appreciated.
thank you
thank you
