Bigfootedalien
- Nov 13, 2009
- 2
I had a Polaris tach in my shop I installed on my 85 115HP Johnson J115MLCOS (eng ran good) took it out got it up running - Tach was working then all of a sudden Tach stopped working & eng quite running! Thought it was the Elect fuel pump but its not fuel - Any ideas what installing that Tach could have screwed up? What kind of Tach can I insta& where do I hook it up? My Tach hookup was on the 3wire plugin gray/black/purple in the dash. Now it attemps to run but spits/sputters - compressions all good 4x135lbs! The reason I installed the Tach is I wanted to X RPMs @ FTH with a new prop on the boat! Any idea where the man Valve needs to point on the Primer Solinoid (0582865) on this boat? Thanks Lar
://thumbs2.ebaystatic.com/pict/220467958345_4.jpgll
