mercury compression specifications
skenniston
I am looking at buying a merc outboard - 1997 250 hp EFI with an hour meter showing 178 hours. Compression check shows 100,105,100,110,105,100. What should this motor have for compression with these low hours, or am I being scammed and the motor really has 500 or more hours???
Thanks
Bifflefan
Re: mercury compression specifications
My 74 Johnny has compression at 120 with who knows how many hours on it.
But that is all i can offer you...
daveswaves
Ensign
Thanks
Bearing in mind there are a lot of things that can affect compression testing, not the least of which is highly inaccurate pressure gauges, test being run without the throttle open, dry cyl, carbon build up.....those numbers look low. I would expect a 3 litre 250 hp in good condition to read about 20 pounds higher. The good news is they are relatively even numbers. I would not discount the engine based on those numbers alone. The general condition of the motor should indicate low or high hours as well. A merc dealer can connect to the ecu and tell you more. It may be worth it.
JB
The engine is fine. There is no spec, mostly because of the things Daveswaves mentions, but also because no known fault would cause 6 cylinders to all go bad by the same amount at the same time.
daveswaves
Ensign
Thanks JB, succinctly said.
