I installed my new tach following what I thought were the instructions, but it doesn't read over 4000rpm (or it may be the prop).
I thought I would double check the connections.
On this forum I learned I needed to move the tach wire (brown) from the SwitchBox to the Alternator wire.
There are two identical yellow/red wires coming down from the alt, going to the rectifier.
I downloaded the Teleflex install instructions today and they show the tach wire (from "send" terminal) being connected to BOTH alt wires.
http://www.downloadingfiles.co.uk/t...structionmanuals/99320 rev 10 Tachometer,.pdf
See page 3.
But it doesn't say to connect to both.
Anyone know if I need to connect to just one wire or both?
Thanks,
Sportyinc
See page 3.
Thanks,
Sportyinc
