Re: Mercury 115
You are experiencing cavitation. Most likely there is nothing wrong with the hub in your prop.
You need to trim the motor down as far as it will go in order to get up on plane.
Look at you motor trimmed down all the way and make sure it goes lower than level. If it does not then you need to install a wedge shaped spacer between the motor and transom (with the thick part of the wedge upwards).
Some boats transoms do not have enough angle to allow your motor to trim down far enough.
Once up to speed (and trimmed out) is your engine RPM's correct? 22p sounds like a lot - just make sure it is OK.
Lesser pitch would help you plane easier but you do not want to over-rev.
Get rid of the cinder blocks and let her fly!!!
Regards,
Inline6
