kbait
- Nov 13, 2007
- 2,484
Buddy's motor said it sounded like he hit a log at speed, similar to what an older 18 would do w/bad clutch dog ears.. He says it doesn't do it at trolling speed, but now it's about every 10 seconds at higher speeds. I changed out the gear oil, and it looked fine. Am I correct that the clutch dog in this motor has 3 ears/side as an upgrade to the older 2/side? If the forward gear's receiving surface looks good, can the clutch dog be reversed, if the reverse side ears are good? I've never done a thru-hub exhaust gearcase disassembly, any thoughts? And am I correct in assuming clutch dog/forward gear? Could it be a shift/clutch dog fork? Thanks!!
