My 1972 mercury 1350 has a rectifier installed. It does not seem to do anything to the voltage. When I took it out for the first time my voltmeter read 18 volts on a fully charged deep cycle marine battery.
I have an 15 Amp rectifier / voltage limiter set to 14.4 volts. Would I have any issues replacing the rectifier with this unit ?. It was originally intended for a Kohler engine and has the same three connections with the housing going to ground.
Would the high voltage have had any influence on the ignition pack ? Initially it got up to high rpm's After adjusting the angle to the transom and restarting it did not rev up. Did still manage to go trough a lot of gas however.
any ideas are welcome.
