catfighter
- Aug 11, 2009
- 263
Hello - I'm not good with the fiberglass; in fact, I've never worked with it.
My question is how do I fix holes in the fiberglass when I don't have access to the other side of the hole? The previous boat owner had drilled 1/2" holes into the fiberglass bench seats and now I'm trying to fix plug them/patch them up.
As far as aesthestics is concerned, I don't need it to look perfect, but at the same time I don't want to just slap resin into the holes, either.
Anyway, I have attached a diagram to give you an idea of what I'm working with. There is about 1/4" of fiberglass on top of about 1" of wood. Below that is foam.
If someone can give me advice or point me to a link (or thread that I couldn't find), I would appreciate it.
Thanks!
Thanks!
