I took apart my failed powerhead today. I found cylinder 4 (I think 4 its the port side middle hole) dry of oil. The connecting rod to crank bearing was melted and that portion of the crank was rusted and looked ike it got very hot. There was a small piece of the piston skit broken off floating around in there too. The piston rings are intact and the cylinder walls look OK. Does anyone think tha tthe oiler could stop oil to one hole? Could combustion possibly burn the gas/oil mix in the crankcase? Just looking for opinions thanks.
