when i put the engine in gear it stalls out. doesn't seem to idle correctly. any suggestions?
C captainmunch Recruit Joined Nov 8, 2009 Messages 1 Nov 8, 2009 #1 when i put the engine in gear it stalls out. doesn't seem to idle correctly. any suggestions?
J jonesg Admiral Joined Feb 22, 2008 Messages 7,174 Nov 8, 2009 #2 Re: 1999 90 hp optical ignation won't idle in gear Compression test. Spark gap test. Ignition timing set up by the book (not clymer or seloc). Rebuild the carbs with new kits. Get the book here, www.outboardbooks.com
