Re: OMC Johnson lower unit will it fit?
As a direct bolt on and go answer is no... the unit will work if you do a couple of slight mod's. If you have the 25" model you should have the 2 piece driveshaft which you can have removed and installed in the 1993 unit. It takes a driveshaft removal tool and about 20 minutes to swap both.
