1996 90 Johnson
Knot at Work
I recently bought a '96 model 90 johnson. Took it out for the first time and I had to get towed in. The motor runs fine, I heard a clonk clonk noise and lost propulsion. With the motor off and in gear I cannot turn the prop. In nuetral I can turn the prop. Seems to me that it is going into gear. Any suggestions?
Dhadley
Re: 1996 90 Johnson
Might just be a spun hub (although that might not explain the noise). Did you try your spare prop yet?
Knot at Work
Re: 1996 90 Johnson
I checked the lower unit oil and it smelled like burnt oil and had metal shavings in it.
