I have a Merc 4 stroke that has a little bit of starting problems. This engine doesn't have your regular push/pull type choke on it, it is some kind of acctuator. What happens is that there is a needle inside that when not in the choke mode is down blocking the passage and when it is in choke mode the needle rises to allow fuel to go by.
I was wondering if anyone knew how I can test this? Ohm tester? put juice to it and see if it works? The part number is 827473M. It is round black and has 2 wires coming off. If it is bad I need to replace it right away as Mercury doesn't make anymore and the shop I called only has 1 in stock. Thanks.
