jwellcraft
- Nov 5, 2009
- 233
Hi, I am having a problem with my trim system leaking down when trimmed up and running. The switches all work fine on the engine and the trim switch on the throttle just when I trim the motor up while running, it goes back down on it's own only if in the water moving. On land tilted up all the way it doesn't move because there is no pressure to pull it down, what could be the problem? And there are no signs of leaks and the fluid level seems to be fine. Also my trim limit switch wires are cut, where do they connect to?
Thanks
Thanks
